no 'Patch/Diagnostic Scripts' tab in SmartZone 5.2.1.0.515 for log4J exploit script.
philip_francis1
Contributor
Hello, I am following the instructions for uploading the log4J fix script, however there is no tab in my SmartZone cluster for 'Patch/Diagnostic scripts' i.e. only a tab within 'Diagnostics' - 'Scripts' for 'AP CLI Scripts'.
Where do I upload this log4j  .ksp script ?
Thank you.
Image_ images_messages_61ce8ce32f2f4a2ecda35b28_8562a806fc8b33c1712b7ac3ea9f79ac_Capture-ba9c6dde-c39a-4093-9ab2-a78946ea1ec3-1829665601.PNG
5 REPLIES 5
Vineet_nejwala
Hi @philip_francis_3lh2kfry55kua
This is strange, are you logged in as admin user ?
Best Regards
Vineet
philip_francis1
Contributor
Hello, yes I am definitely a super-admin. I have full control of the Smartzone cluster.
Usually these symptoms are seen for privileges issue. In case you are using a created "super admin" account, can you once login using the "admin" cred as we have had multiple such cases reported ?
Best regards
Vineet
philip_francis1
Contributor
Thanks, yes, as soon as logging in as the default 'admin' it appeared.
Problem solved.
