Copy SCI Data Partition as backup
pamuditha_abeys
Contributor
Hi
I am planning to take VM backup for SCI. This is to be done as safety measure.
In case of requirement can I spin up SCI node with the copied data partition?
3 REPLIES 3
lakshmi_nagaraj
Hi, can you please elaborate what you mean by a VM backup for SCI? Are you planning to take a VM snapshot?
Also, I would like to get a better understanding of what you mean by "spin up SCI node with the copied data partition", so I provide you with the correct information.
Lakshmi
pamuditha_abeys
Contributor
1.) Sort of. Power down VM and copy data  partition into separate location as .img file.
2.) In case of failure in the original node Create new SCI node with previously copied data partition bound to new VM as data partition.
pamuditha_abeys
Contributor
As an example, let's say I want to move SCI from existing server to new server without loosing existing data. I am planning to copy VM in new server and power it up.
