Hello, I confirmed per this that I am on SPS for both partitions https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/My-ruckus-R510-series-keeps-glitching-out/m-p/52979 . So what else could be the issue?
Happy to share logs.
Thank you
Hi @persepheone
Greetings of the day,
Please let us know the LED status of the switch and the access points using the below guide.
R510 LED lights
https://docs.commscope.com/bundle/unleashed-200.12-onlinehelp/page/GUID-19D4261B-D10B-4DE3-B63A-3498F80103D0.html
RUCKUS LED lights
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-973C8AE8-837A-41C7-9811-BAEF6ADEF3D3.html
When it's working for about five minutes, R510 lights are normal pwr, 2.4 and 5 - green. The switch also has all the normal green lights. But the system then reboots after a few minutes. Once it finishes reboot, lights return to normal.
log here https://github.com/friarfool/log/blob/main/sys
Thanks for your response.
Please share the output of the following commands using the below steps.
ICX7150-C12 Router>
show version
show flash
~ $ screen /dev/tty.usbserial-01A47E6F
SW: Version 08.0.80dT211
Compressed Boot-Monitor Image size = 786944, Version:10.1.14T225 (mnz10114)
Compiled on Thu Nov 15 12:59:22 2018
HW: Stackable ICX7150-C12-POE
Serial #:FEK3814Q2XA
Current License: 2X1G
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 7 second(s)
The system started at 21:26:00 GMT+00 Thu May 18 2000
The system : started=warm start reloaded=by "reload"
ICX7150-C12 Switch>
ICX7150-C12 Switch>Error: Certificate is invalid
Info: Device certificate import is failed ..!!, ret: 21
Creating certificate, please wait...
SSL Client Certificate is successfully created
PS 1, Internal Power supply detected.
PS 1, Internal Power supply is up.
PoE: Stack unit 1 PS 1, Internal Power supply with 124000 mwatts capacity is up
PoE Info: Adding new 54V capacity of 124000 mW, total capacity is 124000, total free capacity is 124000
PoE Info: PoE module 1 of Unit 1 on ports 1/1/1 to 1/1/12 detected. Initializing....
2000 log entries of PoE Event Trace Log Buffer is allocated on unit 1 for unit 1
PoE Event Trace Logging enabled for unit 1
PoE Info: PoE module 1 of Unit 1 initialization is done.
ICX7150-C12-Switch#show version
Copyright (c) 2017 Ruckus Wireless, Inc. All rights reserved.
UNIT 1: compiled on Nov 20 2018 at 00:09:55 labeled as SPS08080d
(25968884 bytes) from Primary SPS08080d.bin
ICX7150-C12-Switch#show flash
Stack unit 1:
Compressed Pri Code size = 25968884, Version:08.0.80dT211 (SPS08080d.bin)
Compressed Sec Code size = 25968884, Version:08.0.80dT211 (SPS08080d.bin)
Code Flash Free Space = 1306087424
ICX7150-C12-Switch#TFTP session timed out
The recommended stable version is 8095g. So please try to upgrade the switch to the code 8095g and let us know the result.
Below are the options or methods to perform the Upgrade on the switch:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-using-a-USB-flash-drive/td-p/46781
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-via-TFTP/m-p/47187
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-an-Upgrade-via-Web-GUI-ICX7150-Switch/td-p/48200
Do you have instructions for upgrading through Mac devices?
Complete the update I think
Compressed Pri Code size = 31457280, Version:08.0.95gT211 (SPS08095g.bin)
Compressed Sec Code size = 31457280, Version:08.0.95gT211 (SPS08095g.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Compressed Sec Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Code Flash Free Space = 1209692160
ICX7150-C12-Switch#
Please confirm whether the issue got resolved or not.
It seems to be stable right now. I will report back again in a couple of days if that's correct. But I can't the Switch to be controllable through Unleashed. It shows as pending, I enter the credentials, but it says the credentials are invalid. Is there an easy fix? Or should I let it be?
Please try the most common username and passwords ( This is key sensitive so please include capital letters )
Username:admin password: Ruckus!
Username:admin password: Ruckus1
Username:admin password: Lennar
Username:super password: sp-admin
Admin usernames and passwords for the Ruckus Wi-Fi Access Points/Switch for Lennar home users
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Admin-usernames-and-passwords-for-the-Ruckus-Wi-Fi-Access-Points/m-p/46740
Also please share the image of the status of the switch showing in the unleashed dashboard
Thank you. See attached photo.
Re. the credentials, I was able to login to the switch IP web interface with no problem with the credentials I set through the CLI. So I'm not sure why those credentials are not working to authenticate through Unleashed.
Taking consideration that the unleashed dashboard/ application have their own credentials and to manage the access points and the switch has other credentials to manage the switch.
These are the credentials for the switch.
Usernames: Passwords:
admin sp-admin
super Lennar
lennar
ruckus
Ruckus!
Ruckus1
admin
password
Also please confirm whether you are able to login to the unleashed app using the same credentials.
Please enter to enter the correct credentials again and let us know the result.
None of those combinations work 😕 What's the next best course of action? Thank you
If the default credentials does not work we need to perform password recovery process.
For that we need physical access to the ICX-7150-Using the console connection.
Here is a short guide :
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12CP-Ruckus-Switch/td-p/46759
Short Guide for password recovery :
https://support.purdi.com/hc/en-gb/articles/360016495292-Ruckus-ICX-Password-Recovery-Resetting-a-Switch
Video link as reference : https://www.youtube.com/watch?v=XJS28DWbHM4
1.Start a CLI session over the serial ( console access) interface to the RUCKUS ICX device.
2-Enter OS mode. This uses a key combination and drops below the fastiron operating system
Key Combination: Ctrl+y, release, tap 'm', tap 'Enter'
OS>
4-just write reset
OS>reset
5-.While the system is booting, before the initial system prompt appears,enter b to enter the boot monitor mode.
In this Part you have to press B before the counter ends
6-Enter no password. (You cannot abbreviate this command.)
ICX7650-Boot> no password00 00 00 00OK! Skip password check when the system is up.
7-Enter boot. This command causes the device to bypass the system passwordcheck.
ICX7650-Boot> boot
8-After the console prompt reappears, assign a new password.
device> enabledevice# configure terminaldevice(config)# username USERNAME password PASSWORD
