Self-Help Articles
Ruckus AP LED indicator meaning
In this article, we will delve into the meaning behind these LED indicators and explain the behaviors they may exhibit. The LED lights on Ruckus access points (APs) play an important role in providing information about the AP's current status. Whethe...
mcordoba1 by RUCKUS Team Member
  • 1224 Views
  • 0 replies
  • 4 kudos
How to deploy a DCHP server on Windows server 2012
This information pertains to general knowledge for utilization within the context of ICX-Unleashed-SZ-vSZ. Initially, need to connect with the Server Manager. Subsequently, we will install the DHCP feature. The installation choices are discretionary;...
Vsquez_Fer_0-1693500396845.png Vsquez_Fer_1-1693500396852.png Vsquez_Fer_2-1693500396857.png Vsquez_Fer_3-1693500396861.png
How to disable weak SSH chipper and CBC on the ICX switches
Here the switch model used is 7150 series and firmware running are 8095c.Run “show ip ssh config” to view all SSH details.Device#show ip ssh configSSH server                 : EnabledSSH port                   : tcp\22Host Key                   : RSA...
Chandini by RUCKUS Team Member
  • 1117 Views
  • 0 replies
  • 0 kudos
ICX XSS and CSRF Vulnerability
This is vulnerability in the web-based management interface of the ICX ruckus product.Workaround:Need to disable web management access to the switches using below options.By default, you will see https enabled.Device#show webHTTP server status: Disab...
  • 327 Views
  • 0 replies
  • 0 kudos
Top Contributor Contest
Win a free RCWA or RCNI Certification Exam attempt ($150 USD value) by contributing to the Community! See details at the Contest Page.
