Self-Help Articles
How to make an API call to Ruckus One
 Ruckus One uses JSON Web Tokens (JWT) to secure all endpoints.POST method is used to obtain a jwt.The API response to POST call includes tenantId and token.Token is valid for 60 minutes.POSTMAN:Postman is the tool used in this example to make an API...
MA by RUCKUS Team Member
  • 530 Views
  • 0 replies
Unable to view Fanless option is 8200 running version 10.0.00
Issue noticed:Device(config)#chassis  name        Chassis name  poll-time   Change hardware sensors polling interval seconds  trap-log    Change fan or power supply loggingOptions are not available to enable Fanless mode on 8200 switches.Solution: Fa...
Chandini by RUCKUS Team Member
  • 361 Views
  • 0 replies
  • 0 kudos
How to enable Dynamic PoE power on the ICX switches:
The power management on the ICX switches until version 9010 have Static Power Management only where we have inline power enabled on the interface by default.Dynamic Power management helps with dynamic power allocation on the ports based on power cons...
  • 1284 Views
  • 0 replies
How to Disable LED Indicators in Ruckus Unleashed
In some situations, administrators may wish to disable the LED lights on the access points to avoid drawing attention to them, when installed in a public location, for example.To disable status LEDs on all APs of a specific model:Go to Access Points ...
mcordoba1 by RUCKUS Team Member
  • 547 Views
  • 0 replies
  • 3 kudos
How to troubleshoot DHCP issues on Ruckus ICX switch
Basic troubleshoot steps:[+] Always collect the packet capture to verify the DORA process[+] If the problem started after upgrade or downgrade - reconfigure DHCP on ICX device.Check if any difference in commands in previous version to new version[+] ...
va10461 by RUCKUS Team Member
  • 744 Views
  • 0 replies
  • 0 kudos
Top Contributor Contest
Win a free RCWA or RCNI Certification Exam attempt ($150 USD value) by contributing to the Community! See details at the Contest Page.
