multiple vlan with different DHCP pool
daniel_ling_i7i
Hi Guys,
I need some help, i am using an 7450-24p with an router image running on version 08.0.80e.
i enable dhcp server on the switch. i am trying to have 2 vlans with different ip subnet.
below is my config, did i miss or do anything wrong over here? as i am not able to get any ip from it.
show run
Current configuration:
ver 08.0.80eT213
stack unit 1
  module 1 icx7450-24p-poe-port-management-module
  module 2 icx7400-xgf-4port-40g-module
  module 3 icx7400-qsfp-1port-40g-module
  module 4 icx7400-qsfp-1port-40g-module
global-stp
 spanning-tree
vlan 10 name IP-subnet_192.168.1.0/24 by port
 untagged ethe 1/1/1 to 1/1/12
 router-interface ve 10
 spanning-tree
vlan 20 name IP-subnet_192.168.2.0/24 by port
 untagged ethe 1/1/13 to 1/1/24
 router-interface ve 20
 spanning-tree
ip dhcp-server pool wifi
 excluded-address 192.168.1.1 192.168.1.10
 lease 1 0 0
 network 192.168.1.0 255.255.255.0
 option  3 ip 192.168.1.1
 option  6 ip 8.8.8.8
deploy
ip dhcp-server pool smart
 excluded-address 192.168.2.1 192.168.2.10
 lease 1 0 0
 network 192.168.2.0 255.255.255.0
 option  3 ip 192.168.2.1
 option  6 ip 8.8.8.8
 deploy
interface ve 10
 port-name wifi
 ip address 192.168.1.1 255.255.255.0
interface ve 20
 ip address 192.168.2.1 255.255.255.0
11 REPLIES 11
BenBeck
Hey Dan,
Do you have "ip dhcp-server enable" in your configuration? It is a global command.
Hi Ben, Yes dhcp-server is enable.
Interesting. I don't see anything wrong in your configuration although it is just a snippet. Are you learning mac-addresses probably on the ports? "show ip dhcp-server summary" and "show ip dhcp-server binding" should give you a clue about whether the switch is trying to serve addresses.
yea i dont get it why is not working... i will get "show ip dhcp-server summary" and "show ip dhcp-server binding" to show you when i am back to office.. anything else i should check?
