05-10-2023 04:13 PM
Ruckus switch has no lights on ports but yellow lights on ruckus switch (to the left of ports) continually flash. R510 access points upstairs & downstairs initially light up and then goes out and do not power back on. No other devices plugged into ruckus work.
05-11-2023 02:13 AM
Thank you for reaching us.
1) Could you please let me know if you are from Lennar homes ?
2) Could you please upload the pic of the front panel of the switch ?
3) If AP's are connected to the switch , Please help us with picture of the front panel of AP device as well to note on LED indication.
4) Please check the below link and try taking a console access to the switch. Try to do a software recovery . In case you are encountering a issue during the upgrade procedure or during console access to the switch. Please upload the picture to this post.
Console access to switch link :
Software recovery procedure :
I hope the above details help you
05-13-2023 08:45 AM
05-15-2023 01:44 AM
Hi Mars55
Ack and Noted. Thanks for reverting back to us.
Could you please let us know how long the switch is able to stay powered on ?
Could you please upload the pictures here to this portal using below option.
05-16-2023 08:37 AM
Switch no longer powers on.
