High CPU on ICX7450 running 09.0.10f
frnkblk
Last night we experienced several systems on our three-member ICX7450 stack:
  • alarms about BGP sessions bouncing
  • could not SSH in via inband or OOB interfaces
  • received alerts from some attached devices that some LACP-enabled LAGs bounced a few times
  • SNMP-based graphs were not
  • ICMP-based pings timed our had high latency
Everything pointed to a high CPU.
We failed to get proper serial interface in place, so we power cycled unit #1 and then took the opportunity to upgrade from 09.0.10c to 09.0.10f. Unfortunately a few hours later we lost SSH, saw ICMP ping failures, and SNMP-based graphing, though we haven't seen any BGP sessions bouncing.
Via the serial interface we could see CPU 0 was high, and these are the processes that high:
2564 root -20 1 678.8m 381.2m 8.0 19.1 48:00.38 R `- bcmINTR
2703 root 26 6 678.8m 381.2m 36.0 19.1 44:34.67 S `- bcmCNTR.0
2742 root 21 1 678.8m 381.2m 12.0 19.1 41:20.12 R `- bcmRX
2807 root -18 6 678.8m 381.2m 28.6 19.1 131:01.63 R `- ZMQbg/1
2988 root 26 6 678.8m 381.2m 16.0 19.1 89:58.03 S `- os_pkt_intx_tx
Best guess is that something is hitting the CPU pretty hard.
Is there a way to see what packets are hitting the CPU?
3 REPLIES 3
Mayank
RUCKUS Team Member
Hi frnkblk ,
Thank you for posting you query !!!
 I comprehend that you were experiencing multiple issue on ICX7450 STACK and that points towards high cpu
and you would like to know what packets are hitting the cpu .
Below is the command where you can see what packets are hitting cpu .
- Dm raw mode brief
- Dm raw filter none
- Dm raw max 10
- Dm raw
But i would suggest you to run the above under tac supervision on a session .
Moving Forward If this issue is not resolved , Please log a ticket with the below link so that we will help you further
I hope this information helps you
Please feel free to leave us a message if any concerns
frnkblk
Thanks for that information.
Based on the output, I set the arp-age timeout for the VLAN used for the router's inband management to "0" (which is infinite) and immediately the CPU dropped.
Any idea why?
Mayank
RUCKUS Team Member
Hi Frnkblk,
Thank you for the update .
As I can see after changing arp-age timeout for the vlan the cpu dropped . I am suspecting  ARP cache were retaining the  learned entries that are no longer valid that's what triggering the High cpu.
Moving Forward If this issue is not resolved , Please log a ticket with the below link so that we will help you further.
