Compatibility M510 & R510
soulcage57
I have 10 AP of R510 unleashed network, can I add M510 AP to this network? will it be compatible?
R510 APs are running system version 200.7.10.2.339 as well as M510
6 REPLIES 6
sanjay_kumar
RUCKUS Team Member
Hi @soulcage57
M510 and R510 are compatible in 200.7.10.2.339. You should be able to add the M510 APs.
Hi @soulcage57
Below is the guide or the version 200.7.10.2.339
https://support.ruckuswireless.com/documents/2599-ruckus-unleashed-200-7-ga-user-guide/download
The limitations and deployment considerations are still the same as below, but please go through it once before adding the M510 APs with R510 network.
Vineet_nejwala
Hi @soulcage57
For future reference you can always look into the upgrade guide or the release note of any specific code and the listed supported model APs will always be compatible with each other (for a mix model network).
https://support.ruckuswireless.com/products/82-unleashed-and-multi-site-manager?open=document#sort=r...]
Best Regards
Vineet
Vásquez_Fer
Hi @soulcage57
Hope you are doing well !
The M510 device has some limitations, please refer to the following image:
Link: https://support.ruckuswireless.com/documents/4320-ruckus-unleashed-200-13-user-guide
Best Regards
Fernando Vasquez
