03-14-2023 04:24 AM
I have 10 AP of R510 unleashed network, can I add M510 AP to this network? will it be compatible?
R510 APs are running system version 200.7.10.2.339 as well as M510
03-14-2023 05:50 AM
Hi @soulcage57
M510 and R510 are compatible in 200.7.10.2.339. You should be able to add the M510 APs.
03-14-2023 08:10 PM - edited 03-14-2023 08:10 PM
Hi @soulcage57
Below is the guide or the version 200.7.10.2.339
https://support.ruckuswireless.com/documents/2599-ruckus-unleashed-200-7-ga-user-guide/download
The limitations and deployment considerations are still the same as below, but please go through it once before adding the M510 APs with R510 network.
03-14-2023 06:34 AM
Hi @soulcage57
For future reference you can always look into the upgrade guide or the release note of any specific code and the listed supported model APs will always be compatible with each other (for a mix model network).
Best Regards
Vineet
03-14-2023 09:05 AM
Hi @soulcage57
Hope you are doing well !
The M510 device has some limitations, please refer to the following image:
Link: https://support.ruckuswireless.com/documents/4320-ruckus-unleashed-200-13-user-guide
Best Regards
Fernando Vasquez
