02-22-2024 05:41 AM
Hello everyone, i got Ruckus T310C Multimedia Hotzone Wireless AP with soft 118.2.0.0.875 , how can i configure time in it?
One of the AP showing 1970 Year another showing 2024 but time and day is incorrect
02-22-2024 07:23 PM
Hi @david2
Ruckus APs by default uses ruckus ntp "ntp.ruckuswireless.com", so just ensure that the AP has internet access to reach to this site.
However, you can still configure and set the NTP under "Configuration > Internet >> and entering the host name in the NTP server option.
If the settings are correct and the time is still showing incorrect under "Status >> Device", then try below steps:
1. Reboot the AP.
2. SSH to the AP >> From the CLI, use the below command
set ntp sync_interval 60
set ntp update
3. Reboot the AP and check the details.
02-22-2024 11:34 PM
Hello, tried this,
** Ruckus T310C Multimedia Hotzone Wireless AP: 121803004811
rkscli: set ntp sync_interval 60
OK
rkscli: set ntp update
OK
rkscli: recvfrom: Connection refused
02-22-2024 11:38 PM
02-23-2024 12:03 AM
NTP sync interval set to 60 minutes, but nothing changed, in status device time is:
Current Time (GMT): Thu Jan 4 16:43:30 2024
