I have R510 I am sick and tired of shitty firmware! Which Firmware is most stable?
dariusz_basiaga
I have R510 I am sick and tired of shitty firmware! At this point I don't care about features I just want this to work without constantly loosing connections and rebooting!  Which Firmware is most stable?
I have 3 of the AP as part of my Lennar Home and I am highly regretting that install!  Every new firmware causes some issues, small issues i could live with but loosing connectivity every few hours and the routers rebooting is just a cheap router problem!  I can't believe that this is being sold to some office deployments!
I have Alexa that plays background white noise so my toddler could sleep while wife and I could do stuff around the house.  Well that is out the window when suddenly at 10 pm the wifi is lost and we are forced to go into his room and re-enable the white noise thus waking him up.  Rinse and repeat 2 hours later.
2 REPLIES 2
syamantakomer
Upgrade to 200.10.10.5.246.
Also check what is causing the disconnections, is it AP reboot or something else.
It can also be wireless connectivity issue due to many other reasons. Login to system and see if you are seeing frequent reboots in even logs.
Syamantak Omer
Official Rep | Staff TSE | CWNA | CCNA | RASZA | RICXI
hayward_kong
Contributor III
What unleashed firmware version are you using?  and what router are using? and who is your provider?  I have no issues with the Ruckus R510/R610/R710 with current firmware with my clients. Perhaps you might have other issues that may seem that it's the Ruckus... Are you saying you have certain devices that drop wifi after a certain period and that you would have to reconnect? I would first suggest that you assign a static IP to each of your Ruckus R510 APs through your DHCP server which would be on your main router which could be provided by your ISP. Also disable the wifi on your ISP router if it has one.
