routing on fastiron gs648p help
i have troulbe routing with this. please help.
 have a network with two vlans. both port based
vlan 3 is the major network. devices on it have a subnet of 192.168.1
vlan 10 is a minor network , ip subnets 192.168.10.
in one port on vlan 3 is a router to the outside world, ip address 192.168.1.254
I've added some router hops and a default as you can see below.
from vlan 10. i can ping the router interface from vlan 3. 192.168.1.4, the pc ii was using has an ip of 192.168.10.200
it pingsa 192.168.1.4 (router interface on vlan 3) with no problems, but fails to ping the router on 192.168.1.254 also on vlan 3. why?
thank you
the config is below.
flash version FGSL07202a.bin (layer 3)
ver 07.2.02aT7e1
module 1 fgs-48-port-management-module
vlan 3 name main by port
tagged ethe 0/1/29
untagged ethe 0/1/3 to 0/1/12 ethe 0/1/15 to 0/1/28 ethe 0/1/30 to 0/1/48
router-interface ve 3
vlan 10 name studios by port
tagged ethe 0/1/29
untagged ethe 0/1/1 to 0/1/2 ethe 0/1/13 to 0/1/14
router-interface ve 10
aaa authentication enable default local
boot sys fl sec
ip default-network 192.168.1.4/24
ip dns domain-name lincolncityradio.com
ip dns server-address 192.168.1.254 8.8.8.8 8.8.4.4
ip route 0.0.0.0 255.255.255.255 192.168.1.4
ip route 192.168.10.4 255.255.255.255 192.168.1.4
ip route 192.168.1.4 255.255.255.255 192.168.10.4
username tech password .....
web-management frame front-panel
web-management frame bottom
web-management page-menu
web-management enable vlan 3
interface ethernet 0/1/29
dual-mode
interface ve 3
ip address 192.168.1.4 255.255.255.0
interface ve 10
ip address 192.168.10.4 255.255.255.0
4 REPLIES 4
Esteemed Contributor II
Does the 192.168.1.254 outside world router on VLAN 3, also have a route back to your VLAN 10 subnet thru 192.168.10.4, your switch IP?
i hoped to resolve that on the inside router as the outside router  doesn't seem to have a configerable router table.
I think that might be the problem though as  i don't get a unreachable error on the terminal on vlan 10, it's gets no feedback at all. just sits there.
Yep, outside router doesn't know what to do with the return packet..., which is an RFC-1918 private network too...
i would have thought the switch router would be able to handle it.
