Openflow on ICX7150-C12P
richard_thornto
Hi There,
I would really like some help, please, does anybody know if the ICX7150-C12P supports Openflow, I have searched google, I can't find a "feature navigator" (like some of the other vendors have) where I can select a model / software version / feature, no clues apart from https://www.ruckussecurity.com/ICX-7150-C12P.asp under "Feature Set" shows:
SDN features
OpenFlow v1.0 and v1.3
OpenFlow with hybrid port mode
Operates with an OpenDayLight Controller
With a note at the bottom for this "Feature to be supported in a future release" but this might not apply to the C12, not sure?
If it is supported is there any way to find the required software version?
Cheers
Richard
4 REPLIES 4
hashim_bharooc1
Contributor III
Hi Richard,
Hope you are doing Great!.
Yes it is supported on 7150s.  I found this in the SDN guide:
https://ruckus-support.s3.amazonaws.com/private/documents/2129/fastiron-08070-sdnguide.pdf?AWSAccess...
Supported hardware
This guide supports the following Ruckus products:
• Ruckus ICX 7750 Series
• Ruckus ICX 7650 Series
• Ruckus ICX 7450 Series
• Ruckus ICX 7250 Series
• Ruckus ICX 7150 Series
Hope this helps.
Hashim
simon_pollard
Contributor II
Hi Richard
You can get access to the ICX documentation here https://docs.arris.com/bundle?labels=31&labels=37&labels=36&labels=35&labels=34&labels=34&labels=33&...
There is a feature support matrix that shows support per platform, OpenFlow page https://docs.arris.com/bundle/fastiron-08090-featuresupportmatrix/page/GUID-6D62D5D1-AC1F-4CC2-8C4E-...
Simon
richard_thornto
Thanks Hashim & Simon!
hashim_bharooc1
Contributor III
Most  Welcome Richard!
Happy Holidays to you.
Hashim
