My dumb arse erased primary and secondary firmware on ICX7150 now I am stuck at boot.
dariusz_basiaga
Now I am stuck at Boot and that's it. (my plan was to upgrade it from it's ancient 2018 to the current 9 version but alas I guess I've missed a step)
What are my next steps? 🙂
1 REPLY 1
Vásquez_Fer
Hi @dariusz_basiaga
Hope you are doing well
Is quite simple to recover the Unit from boot mode:
The first step is to connect an ethernet to the ICX management port and assign an IP on the PC that is of the same range that we are going to configure in the commands below.
Then console the unit and follow the below parameters
  • setenv serverip [IP Address]   >>>  IP address of TFTP server
  • setenv ipaddr [IP Address]  ?>> IP address assigned to switch
  • setenv netmask [Netmask x.x.x.x]
  • setenv gatewayip [Default gateway]
  • setenv uboot [Boot image.bin]
  • setenv image_name [Image Name.bin]
Display the Boot Settings
  • printenv
Uploading Bootrom
  • update_uboot
Uploading Firmware
  • update_primary      >>> Updates primary firmware bank
  • update_secondary  >>> Updates secondary firmware bank
Here is the data that shows this process (software recovery from boot mode)
https://docs.commscope.com/bundle/fastiron-08090-upgradeguide/page/GUID-9B5D5A56-039D-44FB-8FD2-B9B5...
Here is a video link that shows this process:
https://www.youtube.com/watch?v=RHriOYYD_iI
I hope this information can be useful for you
