ICX7150 running x.95 and unable to connect to Unleashed (it stuck at connecting)
dariusz_basiaga
I thought I followed the correct method to setup a telent and webclient and issue crypto keys and username and password but alas the switch won't show up in the Unleashed app under switches.
1 REPLY 1
Vásquez_Fer
Hi @dariusz_basiaga
I would like to know if you are Lennar home user , since some times the switch is running routing code (SPR08095d) (L3) and for this type of setups and configuration ( since you already have a Router on your regular setup ) , it has some troubles for the connectivity for home users.
As I can see you are having troubles adding the ICX to the unleashed dhabsoard, I will share with you some guides to follow up
1-Made sure that the ICX is in the same subnet ( network) as the APs run a
ICX7150-48P #show ip address
2-Unleashed side:
https://docs.commscope.com/bundle/unleashed-200.9-onlinehelp/page/GUID-A887C55E-6973-4496-9413-302E8...
3-ICX configuration and steps:
https://docs.commscope.com/bundle/unleashed-200.8-onlinehelp/page/GUID-A446EC1D-FC2C-4546-BE26-FDE4C...
4-Please ping the ICX from the unleashed dashboard I believe is in
Admin & Services > Administer >Diagnostics> Network Connectivity page.
Some tips I can give you is to run the following commands:
ICX7150-48P (config)#Crypto key generate
Example:
ICX7150-48P (config)#Username admin password admin
ICX7150-48P (config)#aaa authentication login default local
Then in the unleashed dashboard you have to go to switches and use the same credentials you ran as the example admin/admin
I hope this helps !!
