Customizing web authentication on ICX7250
oreste_esposito
Hello everybody,
I am working on a web authentication page for an ICX7250.
I have already customized top, bottom, title, login, button and logo.
I was wondering if there is a way to customize also the remaining lines (what I highlighted below).
Thanks for the support.
Image_ images_messages_5f91c3f4135b77e2478f8e94_08f3409249b42187cc6c2df140771197_RackMultipart20191024629891siq-e633df98-b4be-4790-b87d-e2633449b586-1082579088.png1571929297
2 REPLIES 2
jijo_panangat
Contributor III
Hello Oreste,
This customization should be under Firefox's CP web login page editor/settings if i am not wrong. In case not listed, you may get in touch with the vendor for checking the feasibility.
 Ruckus ICX implementation of Captive portal with Ruckus Cloudpath, Aruba Clearpass & Cisco ISE is below.
https://docs.arris.com/bundle/fastiron-08090-securityguide/page/GUID-411461B6-1DB7-4455-B12A-6C870C5...
oreste_esposito
Hello Jijo,
thanks for your reply, I will try it as soon as possible.
Oreste
