09-09-2024 06:56 AM
After power outage experiencing poor/intermittent internet connectivity. Suspecting the switch is running routing code as documented here:
Following instructions to locate the switch IP and am unable to locate the IP as documented here:
09-20-2024 10:20 AM
Hi @BT
Greetings of the day!!!
Thank you for sharing the requested information on an private chat.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not working with console cable to access CLI and not getting IP address assigned from the ISP (Internet Service Provider's) Router. Checked with multiple troubleshooting steps. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Thank you again. We really appreciate your patience and understanding.
09-10-2024 05:38 AM
Hi @BT
Could you please follow the procedure outlined below and check the results?
1. Press 'b' as demonstrated in the video.
2. Enter the following commands:
Please perform these steps and let me know the outcome.
09-12-2024 05:44 AM
Hi @BT
Thank you.
09-12-2024 04:30 PM
Hi Imran,
I was able to run the factory set-default command successfully. The switch booted both images without error. However, I’m still prompted for login. What steps should I be performing after the factory set-default step?
09-13-2024 05:37 AM
Hi @BT
Yes, after the Switch reset, there will be a default password.
Could you please once again try with the Switch default credentials as mentioned below?
Username: super
Password: sp-admin
If the above credentials don’t work, you can try the default credential combinations mentioned below in the screenshot.
Please try and let me know if that works.
09-13-2024 01:31 PM
Hi Imran,
Thank you for your guidance I have been able to successfully login with a combination of username and password from the screenshot. I have also reset the password when prompted. What steps should I now perform?
