ap's not working after power outage
SUZYRUS
I'm having the same issue as so many others, after the power outage my Syst light is amber and the Pwr light is green and no power to my ap boxes .  I saw you suggested:
1-Please try to disconnect from the Power outlet the ICX-7150 and reconnected.
  1. Remove power from the switch.
I am not tech savvy, I had someone set up the system last year when I purchased the house.  I would have no idea how to set anything up.  will doing the reset wipe out all the information in the switch.  And lose my passwords that were set up with all my devices?
3 REPLIES 3
Imran_ruckus
Hi @SUZYRUS
Hope you are doing well!!!
Thank you for the detailed information you shared,
As per the case description, I could understand that after a power outage, your ICX-7150-C12P Switch is stuck in boot mode.
As you mentioned, there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch. Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
Please do not worry, it will not erase any password or configuration from the Switch or any devices.
As you already know first we will try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
Please let us know once you finish this process. So that we could assist you in upgrading your Switch to the latest stable version to avoid these issues in the future.
Lennar Home Community.
I tried the reset, however now system lights are blinking Amber.  How long should it take
Hi @SUZYRUS
After trying to reset, if you still have amber lights on your ICX-7150-C12P Switch, please proceed with the software recovery process as described in the previous post.
Please help us with the screenshots of the errors (if any) or let us know if you are stuck at any point of troubleshooting. We will help with it and proceed to resolve the issue.
