Wifi for ruckus is freezing and slowing up after power outage
CK
After a power outage the internet is now working slower than before. It freezes up. Was running fine before. We have reset entire Ruckus box by unplugging. Also reset the boxes on each of the 3 floors in my house and still nothing has worked. What can we do? I was going to go best buy and just another wifi extender. Any thoughts?
1 ACCEPTED SOLUTION
Hi @CK  !
I shared the wrong guide is this one since you know the IP address from your switch
How to remotely access to 'ICX 7150-C12P' or 'access points' "Network devices"
Best Regards
Fernando Vasquez
68 REPLIES 68
Hi @CK
Correct that should be the code that should be running  SPS08090d
Best Regards
Fernando Vasquez
Ok..so i did the next step as you instructed. I hit reset. Nothing has happened. I tried logging back in and still experiencing the lag.
Hi @CK
So the next step will be accessing via SSH or Telnet
How to Access an ICX Switch remotely via SSH or Telnet
Admin usernames and passwords for the Ruckus Wi-Fi Access Points/Switch for Lennar home users
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Admin-usernames-and-password...
How to Fix Routing 'code issues' on Lennar Home users
Enable
copy flash flash secondary
Boot system flash secondary yes
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu...
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-cod...
If that does not work please get another console cable and tried the steps that peter mentioned to access by a console cable.
Best Regards
Fernando Vasquez
here is what happens when i try to run that.  I have tried this method before from your earlier one.
Hi @CK  !
Best Regards
Fernando Vasquez
