Switch in boot mode after power outage
nimittsarda
We had a power outage recently after which the AP points do not boot up. I connected my laptop to the Ruckus ICX 7150-C12P Switch via putty but the switch remains in "boot" mode. I tried booting from primary and secondary partition but for both it says corrupted.
So I followed instruction in this link to try and install new image, however now I am stuck at "host 192.168.0.2 is not alive" I set all the required environment variables (as can be seen from the snip below). Please help!
printenv
baudrate=9600
ipaddr=192.168.0.3
serverip=192.168.0.2
netmask=255.255.255.0
gatewayip=192.168.0.2
uboot=mnz10115.bin
image_name=SPR08090d.bin
ver=10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
Environment size: 189/16379 bytes
ICX7150-Boot>ping 192.168.0.2
Change GMAC speed to 1000MB
Using bcm_xgs_gmac-0 device
ping failed; host 192.168.0.2 is not alive
ICX7150-Boot>
11 REPLIES 11
nimittsarda
Hi nimittsarda
Hope you are doing well!!!
From the case description, I could understand that after a recent power outage, AP is not booting up.
Could you please let us know if you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture)
As you mentioned that Switch is stuck on boot mode, do you mean the Switch with amber light on "SYST" and a green light on the "PWR”?
Thank you.
Lennar Home Community.
nimittsarda
Thank you Imran for the quick reply.
SYST has amber light and PWR has green light. Others are off
For boot mode, I connected my laptop to the switch and logged in. There it says "ICX7150-Boot" (refer the image in the post.
Hi nimittsarda
Could you please provide an image/photo of where you are trying to connect via console / Ethernet from ICX 7150 - C12 P (USB type C to USB ) to the PC. (Physical setup)? like the following example:
