Ruckus icx 7150-c12p very very slow after power outage
gooji18x
My case is exactly the same as the following thread.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Ruckus-icx-7150-c12p-slow-af...
I have already tried connecting to my switch but unable to find the IP address for the switch via Advanced IP scanner.
I do see my wireless Ruckus access points, but my switch doesn't show up. I see the MAC address on the unit, but it does not show up in the Advanced IP scanner.
3 REPLIES 3
Hi @gooji18x
Greetings of the day,
Thanks for the information provided.
As per the information you have shared it seems that the switch starts running the wrong code which we call ‘routing code’ this is a known issue.
If access via IP address is not possible here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
ICX7150-C12 Router>
Please follow the below steps on how to fix the 'routing code issue' by running the following commands once you are on the command line 'CLI'
copy flash flash secondary
Example:
There are Two ways to fix this issue:
          I)    How to Fix Routing code issues on Lennar Home users via CLI
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu...
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-cod...
          II)    Or WEB access option
lardassresponde
Here is a guide on how to access the Switch via console (cable access between your PC and the ICX 7150-C12P) if access via IP address is not possible. In this instance, we need a USB type C to USB standard or Console cable Rj45 to USB. https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu geometry dash scratch
Hi @lardassresponde
Please let us know if your issue got resolved or not.
Also please let us know if you have any queries in this regard.
