03-05-2023 09:16 AM
I tried restart, factory reset and updating from USB but still not able to solve the issue...
Ruckus Wireless Bootloader: 10.1.14T225 (Nov 15 2018 - 04:59:18 -0800)
Booted from partition 2
DRAM: Validate Shmoo parameters stored in flash ..... OK
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
device 0 offset 0x0, size 0xc0000
bootdelay: ===
Booting image from Secondary
NAND read: device 0 offset 0x4000000, size 0x2000000
8 ecc_errors after reading 58b8000:58b9c00
iproc_nand_read_page returned 2
NAND read from offset 4000000 failed -22
0 bytes read: ERROR
## Loading kernel from FIT Image at 70000200 ...
Bad FIT kernel image format!
ERROR: can't get kernel image!
could not boot from secondary, no valid image; trying to boot from primary
BOOTING image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
6 ecc_errors after reading 18b8000:18b9c00
NAND read from offset 0 failed -22
0 bytes read: ERROR
ICX7150-Boot>hwinfo
SKU : 12 (POE), PVT1
System CPLD Version : 0x4:0xa
CPLD Chip Select : 2
Bank Select : 1
Watchdog PCA9561 Enabled : 0
Watchdog Enabled : 0x30
NAND type : Micron NAND 2GiB (x 1)
Booted from : 1
Primary Uboot Failure Record : 0
Secondary Uboot Failure Record : 0
Reset Cause : PON_RESET
Write Protect NOR Enabled : 0
Write Protect RCW Enabled : 0
Write Protect PCA9561 Enabled : 0
ICX7150-Boot>version
armeb-buildroot-linux-gnueabi-gcc.br_real (Buildroot 2015.11.1) 4.9.3
GNU ld (GNU Binutils) 2.24
