Power outage and currently not providing power to Access Points
normiihack
I am in the same boat as some other that had a power outage due to a storm. I have tried the troubleshooting and I am still not able to access my switch to troubleshoot or get power back to my AP's in my house.
I have tried to SSH into it and it is not seen. I have tried a factory restore and it looks to be stuck as all the lights are amber still after a few hours. Items I do have is a USB A to USB C cable and no luck trying to access it.
While I appreciate the help from the other posts, I do need assistance with doing the troubleshooting on a Mac. I do not have access to a windows computer to do most of the troubleshooting that I have seen on this forum.
Any assistance would be beneficial and if I could actually talk to someone, this would be a lot smoother than waiting for a response.
1 REPLY 1
david_chavarri1
Hi @normiihack
Hope you are doing well
I will add the console Access to the switch ICX-7150 ( white box in your closet ) using a Mac computer to the existing  guide:
1-First at all you need to install the drivers to read the cable type C to console the switch in your Mac computer.
Software:
https://www.silabs.com/developers/usb-to-uart-bridge-vcp-drivers?tab=downloads
https://support.ruckuswireless.com/software/1413-brocade-ruckus-7150-usb-serial-driver-mac
2-After successfully installing the Mac Drivers, open the Mac terminal, when you see the command prompt do the following:
Enter this command:
ls /dev/cu.*
This command will display something like this:
One of those logs will say something similar to /dev/cu.SiLabs_Serial (which is related to the drivers you installed)
3-Then enter the following command using the name of the installed driver that was displayed:
screen /dev/cu.SiLabs_Serial 9600
4-Hit Enter and you will have access to the ICX7150’s CLI.  (Comand Line)
Video link as reference: https://www.youtube.com/watch?v=1AcJokMm78U
Here we have to scenarios if you get the following prompt
ICX7150-C12 Switch>
That means that we need to check the PoE ( Power over Ethernet ) Please run the following commands
ICX7150-C12 Switch>show inline power detail
ICX7150-C12 Switch>show version
Copy and paste here to analyze.
Or if you get the following prompt:
ICX7150-Boot>
You can try to boot up from primary image/secondary
boot_primary or boot_secondary
If that does not work we need to preform a software recovery :
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Software-recovery-an-...
This process can be done also in a Mac computer, link: https://www.youtube.com/watch?v=TZMxjHls8A8
Best Regards
