Power Outage - Wireless Access Points not working
Mbar21
We had a power outage and our wireless access points are no longer working. Lights are completely off and the wifi is not showing up as an option. We tried following the steps in other forum posts but have not been able to get it working. Is there a technician that can be sent out to fix this please?
16 REPLIES 16
Ruckus.jpegHello, I'm having the same exact issue.  I'm replying based on your questions above.  Please advise.
1.)SYST is green and PWR is green.
2.) 2 access points (1 downstairs and 1 upstairs)
IMG-2483.jpgIMG-2482.jpgThere are (I think) 4 access points, i'm not sure.
Mbar21
The amber/green lights are flashing, as shown in the pictures i just sent.
Mbar21
Hello? is anybody monitoring this forum?
Hi @Mbar21
Greetings of the day!!!
Hope you are doing well!!!
As we can see there from the picture you shared, amber lights are flashing on the Switch.
Please follow the below steps in order to fix this issue:
First, we will try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
3. We must get console access to the ICX-7150-C12P Switch as mentioned in the steps from the guide below:
How to console in the ICX-7150-C12P:
Below are the Guide and Video Link to perform the Software recovery process:
Please let us know once you finish this process. So that we could assist you in upgrading your Switch to the latest stable version to avoid these issues in the future.
Lennar Home Community.
