PoE not working after power outage
hvganesh
Ruckus unleashed don’t turn on PoE after power outage. I could turn the power on with DC cable.
28 REPLIES 28
Imran_ruckus
Hi @hvganesh
Based on the information provided, it appears that you are encountering issues with RUCKUS devices after a power outage.
When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
None of the lights are lit in PoE but both PWR and CTL are green when connected with power
