PST-ICX Switch is Disconnected after power outage
EduardoC
https://support.ruckuswireless.com/cases/01409741
This is the the same issue as in
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Ruckus-switch-unreachable-di...
But I do not see a solution for that. I am not a network specialist so some suggestions are too technical for me
1 ACCEPTED SOLUTION
Hi @EduardoC
Ok, so if the Online web access is not working, you need to get access via console, using the next connection the USB will be connected on your computer and the type C on your ICX7150 Switch.
Note: the SSH and Telnet access will not work for you, because you are having connectivity issues to reach the IP address 192.168.1.170 and those are for remote access, however console is local, so will no matter if you have or not an IP address.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-cod...
RUCKUS ICX 7150 USB TYPE C CONSOLE (tutorial video for ICX)
https://www.youtube.com/watch?v=YXR4xhkw3q8
(Tutorial for MAC)
https://www.youtube.com/watch?v=1AcJokMm78U
Yarenis Hernández
16 REPLIES 16
Eduardo, did you fix this problem? I think I have same issue on my side and I am not sure how to fix it. My switch also showing disconnected.
Hi @jasminkoplje
Hope you are doing well
As this case is raised by  @EduardoC  which is very old and closed now.
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly.
EduardoC
And to answer your questions...
My Switch is online, but from Unleashes is displayed as disconnected (as in the image I sent you);
We have ATT as a provider. And there is no issue accessing internet when connected to ATT wifi.
But when connecting to Ruckcus access points I am often timed out trying to navigate to sites like cnbc.com, dell.com... All access points are online. Not sure if they works as expected because I am having all the issues accessing internet. I did reboot both switch and access points several time already.
I do not feel comfortable sharing my IP address on a public forum.
Hi @EduardoC
OK, so if the next are your Symptoms, seems the Switch start booting from the incorrect partition, let me add the Guide to solve the issue, please read the guides carefully before start the troubleshooting.
Symptoms:
Websites not loading
Devices getting disconnected or having problems working as intended.
Network dropping at random points in time.
Smart devices not being able to connect to the internet.
Unleashed dashboard sometimes as “Disconnected” on the Internet tab.
Note: your IP address will be always local, so is not routable over the internet, this is why you have your ISP router in the middle to convert those IPs address in your home to an internet IP Address or routable over the internet.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu...
Yarenis Hernández
EduardoC
And WIFI signal strength from AP is fine
