Lennar smart home outage. Wi-Fi running super slow!
JRent
After an outage in the area my Wi-Fi has been running really slow. I need help getting it back to its AMAZING speed that it used to be. Thanks 🙏🏼
11 REPLIES 11
Imran_ruckus
Community Manager
Community Manager
Hi JRent
Hope you are doing well!!!
From the case description, I could understand that your  Wi-Fi is running slow after an outage.
This issue may happen when the Switch start running on the Routing code. The Switch should run on the Switching code to avoid these issues for Lennar home users. Due to a power outage the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
You can take Console access to the switch in order to verify, if the switch is able to connect properly to Access Points or if it has a ‘Routing Code’ issue which happens due to power outages most of the time, this is a known issue for Lennar home users.
-MAC address: Physical address of the device this never changes
- An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
Please follow the below steps:
  1. To fix this issue, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
  1. Once we identify the IP address of the switch proceed to access remotely to the device “Command Line”
ICX7150-C12 Router>
  1. Here is a quick guide for understanding how to fix the 'routing code issue' however, you only need to run the following commands once you are on the command line 'CLI'
show version
copy flash flash secondary
(Please share the output screenshot of the ‘show version’ command)
Example:
There are Two ways to fix this issue:
I) How to Fix Routing code issues on Lennar Home users via CLI
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu...
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-cod...
II) Or WEB access option
  1. If access via IP address is not possible here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '3'
Lennar Home Community.
Too much information for me to understand. Is there any way I can speak to someone that can help me fix the issue?
Hi JRent
I truly Apologize for the inconvenience.
Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email. We will be exclusively supporting customers via this community forum support model.
We have tried to create the guides as non-technical as possible, so that they are not much difficult to follow. However, if you continue to have difficulty following the steps, I would recommend that you seek outside help or a technician.
Please do let us know if there is any help required on the troubleshooting steps or if you are stuck at any point. We are happy to help you.
I have the IP address but don’t know how to access the Command Line.
