Internet Access Sporadic and Slow After Power Outage - ICX 7150 Switch
slaba0815
We had a short power outage and since then the Wifi is working only sporadically and slow. Certain sites/Apps do not work at all when connected to the Access points, however everything works through the Wifi from the provider which leads me to believe its an issue with the ICX7150 switch. I tried to find a solution in the forums but am unable to access the Ruckus switch. None of the passwords suggested works to get access. I need help to fix my connection.
7 REPLIES 7
Hi @slaba0815
Since you are already on a version 8090d in this case 8090d you don't need the boot folder since the new versions UFI ( 8090 code or later )  version include ( everything  in the image.bin file )  the fastiron OS, boot code, POE firmware, etc. all in one .bin
Check on the following guide  from point '20' :
 Via TFTP  example:
The only file need it is the following :
Best Regards
Fernando Vasquez
slaba0815
The good news is that I got the software uploaded and the system appears to be running OK, however I only have one component (a switch) and the accounts (even the super account to administrate) are not working or say no password defined (see response below). Can you advise what I need to do? Thank you ver much.
login as: super
Keyboard-interactive authentication prompts from server:
| Password:
End of keyboard-interactive prompts from server
SSH@ICX7150-C12 Switch>enable
SSH@ICX7150-C12 Switch#show version
    UNIT 1: compiled on May  6 2022 at 23:24:50 labeled as SPS08095g
      (31457280 bytes) from Primary SPS08095g.bin (UFI)
        SW: Version 08.0.95gT211
      Compressed Primary Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
       Compiled on Thu Apr 21 06:08:52 2022
  HW: Stackable ICX7150-C12-POE
UNIT 1: SL 1: ICX7150-C12-2X10GR POE 12-port Management Module
      Serial  #:FEK3809S1LC
      Current License: 2X10GR
      P-ASIC  0: type B160, rev 11  Chip BCM56160_B0
    8 MB boot flash memory
    2 GB code flash memory
    1 GB DRAM
STACKID 1  system uptime is 11 minute(s) 16 second(s)
The system started at 23:55:40 GMT+00 Fri May 06 2022
The system : started=warm start   reloaded=by "reload"
    2 GB code flash memory  STACKID 1  system uptime is 11 minute(s) 53 second(s)
The system started at 23:55:44 GMT+00 Fri May 06 2022
SSH@ICX7150-C12 Switch#Keyboard-interactive authentication prompts from server:
Invalid input -> Keyboard-interactive authentication prompts from server:
Type ? for a list
SSH@ICX7150-C12 Switch#| Password:
Invalid input -> | Password:
Type ? for a list
SSH@ICX7150-C12 Switch#End of keyboard-interactive prompts from server
Invalid input -> End of keyboard-interactive prompts from server
Type ? for a list
SSH@ICX7150-C12 Switch#SSH@ICX7150-C12 Switch>enable
Invalid input -> SSH@ICX7150-C12 Switch>enable
Type ? for a list
SSH@ICX7150-C12 Switch#No password has been assigned yet...
Invalid input -> password has been assigned yet...
Type ? for a list
SSH@ICX7150-C12 Switch#SSH@ICX7150-C12 Switch#show version
Invalid input -> SSH@ICX7150-C12 Switch#show version
Type ? for a list
SSH@ICX7150-C12 Switch#  Copyright (c) Ruckus Networks, Inc. All rights reserved.
Invalid input -> Copyright (c) Ruckus Networks, Inc. All rights reserved.
Type ? for a list
SSH@ICX7150-C12 Switch#    UNIT 1: compiled on May  6 2022 at 23:24:50 labeled as SPS08095g
Invalid input -> UNIT 1: compiled on May  6 2022 at 23:24:50 labeled as SPS08095g
Type ? for a list
SSH@ICX7150-C12 Switch#      (31457280 bytes) from Primary SPS08095g.bin (UFI)
Invalid input -> (31457280 bytes) from Primary SPS08095g.bin (UFI)
Type ? for a list
SSH@ICX7150-C12 Switch#        SW: Version 08.0.95gT211
Invalid input -> SW: Version 08.0.95gT211
Type ? for a list
SSH@ICX7150-C12 Switch#      Compressed Primary Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Invalid input -> Compressed Primary Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Type ? for a list
SSH@ICX7150-C12 Switch#       Compiled on Thu Apr 21 06:08:52 2022
Invalid input -> Compiled on Thu Apr 21 06:08:52 2022
Type ? for a list
SSH@ICX7150-C12 Switch#  HW: Stackable ICX7150-C12-POE
Invalid input -> HW: Stackable ICX7150-C12-POE
Type ? for a list
SSH@ICX7150-C12 Switch#==========================================================================
Invalid input -> ==========================================================================
Type ? for a list
SSH@ICX7150-C12 Switch#UNIT 1: SL 1: ICX7150-C12-2X10GR POE 12-port Management Module
Invalid input -> UNIT 1: SL 1: ICX7150-C12-2X10GR POE 12-port Management Module
Type ? for a list
SSH@ICX7150-C12 Switch#      Serial  #:FEK3809S1LC
Invalid input -> Serial  #:FEK3809S1LC
Type ? for a list
SSH@ICX7150-C12 Switch#      Software Package: BASE_SOFT_PACKAGE
Invalid input -> Software Package: BASE_SOFT_PACKAGE
Type ? for a list
SSH@ICX7150-C12 Switch#      Current License: 2X10GR
Invalid input -> Current License: 2X10GR
Type ? for a list
SSH@ICX7150-C12 Switch#      P-ASIC  0: type B160, rev 11  Chip BCM56160_B0
Invalid input -> P-ASIC  0: type B160, rev 11  Chip BCM56160_B0
Type ? for a list
Type ? for a list
SSH@ICX7150-C12 Switch#UNIT 1: SL 2: ICX7150-2X1GC 2-port 2G Module
Invalid input -> UNIT 1: SL 2: ICX7150-2X1GC 2-port 2G Module
Type ? for a list
Type ? for a list
SSH@ICX7150-C12 Switch#UNIT 1: SL 3: ICX7150-2X10GF 2-port 20G Module
Invalid input -> UNIT 1: SL 3: ICX7150-2X10GF 2-port 20G Module
Type ? for a list
Type ? for a list
SSH@ICX7150-C12 Switch# 1000 MHz ARM processor ARMv7 88 MHz bus
Invalid input -> 1000 MHz ARM processor ARMv7 88 MHz bus
Type ? for a list
SSH@ICX7150-C12 Switch#    8 MB boot flash memory
Invalid input -> 8 MB boot flash memory
Type ? for a list
SSH@ICX7150-C12 Switch#    2 GB code flash memory
Invalid input -> 2 GB code flash memory
Type ? for a list
SSH@ICX7150-C12 Switch#    1 GB DRAM
Invalid input -> 1 GB DRAM
Type ? for a list
SSH@ICX7150-C12 Switch#STACKID 1  system uptime is 11 minute(s) 16 second(s)
Invalid input -> STACKID 1  system uptime is 11 minute(s) 16 second(s)
Type ? for a list
SSH@ICX7150-C12 Switch#The system started at 23:55:40 GMT+00 Fri May 06 2022
Invalid input -> The system started at 23:55:40 GMT+00 Fri May 06 2022
Type ? for a list
SSH@ICX7150-C12 Switch#The system : started=warm start   reloaded=by "reload"
Invalid input -> The system : started=warm start   reloaded=by "reload"
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
Type ? for a list
SSH@ICX7150-C12 Switch#--More--, next page: Space, next line: Return key, quit: Control-c
Invalid input -> --More--, next page: Space, next line: Return key, quit: Control-c
Type ? for a list
Hi @slaba0815
Great to hear that your system is up and running please feel free to mark the post as successful.
What it says is that you have not assigned a password on Privileged EXEC mode.
So to go from >  to #
Switch>enable
Switch#
In order to create the password use the following steps
Configure terminal
enable super-user-password pass
Where 'pass' is the password
Following example
Switch>enable
Switch#
Switch#conf t
Switch(config)#enable super-user-password pass
Switch(config)#exit
Switch#exit
Switch>
Switch>enable
Password:
DISBALE
Switch#
Switch#conf t
Switch(config)#no enable super-user-password pass
Switch(config)#exit
Switch#exit
Switch>enable
Switch#
Best Regards
Fernando Vasquez
