ICX 7150 Switch in Boot Mode after power outage
lightsout
Similar to past and recent posts, after a power outage, the switch has a steady green light for power and steady amber light for system, no power to the 3 Ruckus AP.
I followed previous solutions to hard reset (using a pin) and if no image to boot to try to load one. Unfortunately, while I was able to communicate a few times,  result was that it was "not alive" - similar to this post: https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Switch-in-boot-mode-after-po...
I tried it again today and it appears to be worse - see below. It seems to stay on the last "Releas321t>23" for a very long time (at least 10 minutes) until I hit enter and it gives me the ▒▒. It does not allow any commands and continues to repeat ▒▒ and delete itself before starting again. Same thing happens when we tried to reset again.
Please advise of next steps.
Ruckus Wireless Bootloader: 10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
Booted from partition 1 DRAM: Validate Shmoo parameters stored in flash ..... OK
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
Writing Shmoo values into flash .....
device 0 offset 0xbfe00, size 0x200
device 0 offset 0x0, size 0xc0000
bootdelay: ===
Booting image from Secondary
NAND read: device 0 offset 0x4000000, size 0x2000000
8 ecc_errors after reading 5b48000:5b49c00
iproc_nand_read_page returned 2
NAND read from offset 4000000 failed -22
0 bytes read: ERROR
## Loading kernel from FIT Image at 70000200 ...
Bad FIT kernel image format!
ERROR: can't get kernel image!
could not boot from secondary, no valid image; trying to boot from primary
BOOTING image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
8 ecc_errors after reading 1b48000:1b49c00
NAND read from offset 0 failed -22
0 bytes read: ERROR
ICX7150-Boot>23:08OK
Unknown command '23:08OK' - try 'help'
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot>ICX7150-12 (POE), PVT1
Unknown command 'ICX7150-12' - try 'help'
ICX7150-Boot>
ICX7150-Boot>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>S YS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0 x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t> 23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>IC X7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE) , PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS C PLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 R eleas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:0 8Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX715 0-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PV T1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Relea s321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23<INTERRUPT>
ICX7150-Boot>
:t▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒t>
Additional Attempt:
bootdelay: ===
Booting image from Primary
0 bytes read: ERROR
could not boot from primary, no valid image; trying to boot from secondary
BOOTING image from Secondary
0 bytes read: ERROR
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
7 REPLIES 7
Imran_ruckus
Hi lightscout
Hope you are doing well!!!
From the case description, I could understand that after a power outage, your ICX-7150-C12P switch is stuck on boot mode with Green light on PWR and an Amber light on SYST.
I would request you please disconnect the power of your ICX-7150-C12P Switch and power it on again. Then perform the Reset of the switch as described below.
Please follow to below steps in order to fix this issue:
  1. Please try to disconnect from the Power outlet the ICX-7150 and reconnected.
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
  1. We must get console access to the ICX-7150-C12P Switch as mentioned in the steps from the guide below:
How to console in the ICX-7150-C12P:
Below are the Guide and Video Link to perform the Software recovery process:
 https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-r...
Also, please share the screenshots or pictures of the errors (if any) and connections if you are trying to get the console to the Switch.
Lennar Home Community.
Hello Imran,
I performed all that you have listed many times over the weekend with the same results: either ping came back as not alive or the errors that you saw me post.
I’ve downloaded putty, drivers so my laptop can see the COM port, the SW, reset the switch with a pin and connected  successfully to switch with the usba/c cable - same result: solid green light on power and sys solid amber light.
 Can you advise on next steps?
Hi lightscout
Thank you for the response and information.
As mentioned in the previous post, please disconnect the power of your ICX-7150-C12P Switch and power it on again. Then perform the Reset/Software recovery process of the switch as described in the last post.
Please check the videos of these processes mentioned in the same post.
If there is a same error, we request you share the screenshots of the error you are getting And pictures of the connections to the Switch and Laptop/PC.
Hello Imran,
I re-did as you suggested in the posts - Still the same error. SW recovery not possible as commands are not accepted in Putty. Please see attached.
