Have a power Outage and my AP's are not powering up. I have access to SWITCH ICX7150
Swarupbade
3 ACCEPTED SOLUTIONS
Hi @Swarupbade
Thanks for your reply,
Based on your description, it shows that PoE is in disabled state. Please follow the below steps to enable PoE.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-enable-PoE-or-gather-...
Hi @Swarupbade
Please try unplugging and plug the AP which is blinking red. If this step doesnot work please perform a factory reset, let me add the steps, if the Access point still not responding, please reply with a picture showing that the PWR is red.
How to factory reset or factory default different types of Ruckus Access points? (technical guide.)
https://support.ruckuswireless.com/articles/000012418
Hi @Swarupbade
Please follow the below link to perform the upgrade of your switch.
To upgrade your switch to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin, please perform the software recovery using the code 08090k with the upgrade image file named SPS08090k.bin, then when the switch is back to normal upgrade to the file SPS08095gufi.bin for both partitions primary and secondary.
18 REPLIES 18
Unplugging and plugging back worked! Thanks
Please let me know how to update the drivers / software for the switch and APs to ensure I am using the latest version. Thanks.
I just downloaded the App and updated the latest firmware for the AP's, But, how do I update the Switch Firmware??
Hi @Swarupbade
Swarupbade
AWESOME, Thank you!!!
