Have a power Outage and my AP's are not powering up. I have access to SWITCH ICX7150
Swarupbade
3 ACCEPTED SOLUTIONS
Hi @Swarupbade
Thanks for your reply,
Based on your description, it shows that PoE is in disabled state. Please follow the below steps to enable PoE.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-enable-PoE-or-gather-...
Hi @Swarupbade
Please try unplugging and plug the AP which is blinking red. If this step doesnot work please perform a factory reset, let me add the steps, if the Access point still not responding, please reply with a picture showing that the PWR is red.
How to factory reset or factory default different types of Ruckus Access points? (technical guide.)
https://support.ruckuswireless.com/articles/000012418
Hi @Swarupbade
Please follow the below link to perform the upgrade of your switch.
To upgrade your switch to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin, please perform the software recovery using the code 08090k with the upgrade image file named SPS08090k.bin, then when the switch is back to normal upgrade to the file SPS08095gufi.bin for both partitions primary and secondary.
18 REPLIES 18
Hi @Swarupbade
Greetings of the day,
1-On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on?
2- Make sure it is plugged into a well-known outlet/power source
it's green, i just confirmed
My switch is ICX 7150-C12P
based on pic you sent, I have 7 (Sys) and 16 (PWR) both Green. The only issue is with the Access point  not receiving power. I see that ring which is connected to one of the ports in the switch is working. Also, I am sure the ATT router internet is working, as I am currently using it. Please let me know how to power up the AP. Thanks.
telnet@ICX7150-C12 Switch>enable
telnet@ICX7150-C12 Switch#show version
Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Aug 14 2017 at 06:54:44 labeled as SPS08061a
(24723488 bytes) from Primary
SW: Version 08.0.61aT211
Compressed Boot-Monitor Image size = 786944, Version:10.1.10T225 (mnz10110)
Compiled on Sun Jun 25 09:25:15 2017
HW: Stackable ICX7150-C12-POE
Serial #:FEK3204P0WH
Current License:
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 20 hour(s) 43 minute(s) 17 second(s)
The system started at 00:02:05 GMT+00 Sat Jan 01 2000
telnet@ICX7150-C12 Switch#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 124000 mWatts.
Power Allocations: Requests Honored 0 times
1/1/1 Off Off 0 0 n/a n/a 3 n/a
1/1/2 Off Off 0 0 n/a n/a 3 n/a
1/1/3 Off Off 0 0 n/a n/a 3 n/a
1/1/4 Off Off 0 0 n/a n/a 3 n/a
1/1/5 Off Off 0 0 n/a n/a 3 n/a
1/1/6 Off Off 0 0 n/a n/a 3 n/a
1/1/7 Off Off 0 0 n/a n/a 3 n/a
1/1/8 Off Off 0 0 n/a n/a 3 n/a
1/1/9 Off Off 0 0 n/a n/a 3 n/a
1/1/10 Off Off 0 0 n/a n/a 3 n/a
1/1/11 Off Off 0 0 n/a n/a 3 n/a
1/1/12 Off Off 0 0 n/a n/a 3 n/a
Total 0 0
telnet@ICX7150-C12 Switch#show inline power detail
Power Supply Data On unit 1:
Power Supply Data:
Power Supply #1:
Max Curr: 2.3 Amps
Voltage: 54.0 Volts
Capacity: 124 Watts
PoePower: 124 Watts
POE Details Info. On Unit 1 :
General PoE Data:
--More--, next page: Space, next line: Return key, quit: Control-c
