07-09-2021 02:33 PM
I'm currently using FiOS and I called them for support but they have verified that their end is working properly. I am wondering if it is the recent uptick in devices connected to my home network. However, I am questioning that because the other devices are not streaming anything, so I doubt just connecting to the wifi could make it slow down a lot. I restarted the router and updated my ruckus unleashed APs. It seemed to help a little but it still is very sluggish. Any suggestions on why this is happening and what could remediate this?
07-19-2021 01:33 PM
@druski12 to re-enable the network, you have to first access the Unleashed.
Connect a laptop to the same wired network as the AP and then access the AP using its IP address. Once you get in, enable the network you disabled by mistake.
Now for the original issue, check if your ICX switch is booted to wrong image (router image). If yes, make sure you boot it again to SW mode and also update the other boot image to switch image.
show flash
show ver
