VLAN and Subnet Configuration on ZD1100 and 5 x 7900 APs
I'm aiming to setup a working test environment consisting of 1 x ZD1100 and 5
x Zone Flex 7900 APs and 1 x Cisco 3750x L3 switch to power the APs and do the routing:
I want to separate traffic using 4 VLANs and 4 Subnets:
VLAN 10 Management 10.5.10.0/24
VLAN 130 Guest WiFi 10.5.130.0/24
VLAN 140 Production WiFi 10.5.140.0/24
VLAN 160 Staging WiFi 10.5.160.0/24
I've SVIs setup on the Cisco 3750x:
VLAN 10: 10.5.10.1/24
VLAN 130: 10.5.130.1/24
VLAN 140: 10.5.140.1/24
VLAN 160: 10.5.160.1/24
For the time being I'll use the Cisco 3750x for DHCP configured with 3 pools
for VLAN 130,140,160. (Eventually I'll move these scopes to an external DHCP
server.
I want to assign the ZD and APs with management IP addressing in the .10
subnet i.e.:
ZD 10.5.10.50
AP1: 10.5.10.51
AP2: 10.5.10.52
AP3: 10.5.10.53
AP4: 10.5.10.54
AP5:10.5.10.55
At the moment I've the APs and ZD1100 connected to the Cisco 3750x switch via
6 open trunks (Native VLAN 1) respectfully.
eg:
interface GigabitEthernet1/0/1
switchport
description AP01 Testing
switchport trunk encapsulation dot1q
switchport mode trunk
spanning-tree portfast
end
As I'm well aware I'm missing some fundamental information on how the ZD and APs communicate.
My questions are:
What VLANs and subnets do I configure on the ZD1100 and APs ? (I only see an option to configure the ZD as an Access VLAN)
And how do I configure these on ZD1100 and which interfaces do I configure (i.e. management or system or both)?
Thanks in advance for any help received.
4 REPLIES 4
