Default SNMP community in T310C and T310D?
jeff_tuttle
Not in user guide. How does one set a community or see the default SNMP community in T310C and T310D in standalone mode? FW is 114.0.0.0.1360 Many thanks, Jeff
3 REPLIES 3
mitchell_axtell
Contributor II
The commands are CLI only:
set remote-mgmt snmp
set snmp version v2c
set snmp system contact <>
set snmp system location <NO SPACES>
set snmp community ro public
set snmp community rw private
get snmp to view
jeff_tuttle
Thank you.
May I ask where did you found those commands?
Many thanks.
I think it's "help snmp" to show the options in the CLI, but I don't have one handy to check so that may be incorrect.  It should be under systemgroup so if that command doesn't work it would be "help systemgroup".  Basically "help <command>" will show you the options like ? on most switches.
